01-15-2024 07:02 AM
Can anyone help me with this please? I have a schedule set up for my heating but the heating turns on when it feels like it and chooses it's own temp. These are my settings if anyone can help thanks 🙂
01-15-2024 07:06 AM
I can't work out how to attach photos to the post🤔
01-16-2024 10:05 AM
What model of Nest thermostat do you have? It is my understanding that the Nest thermostats all want to 'learn' what your behaviors are so it can take over the schedule. So, yes, it's turning on/off the heat when it feels like it. There may be a way to disable the 'learned' features but that kind of defeats the purpose of the Nest.
01-17-2024 10:49 AM
Thanks for reaching out. I'd like to know more about it. A few questions: what type of Nest Thermostat do you have? In what country are you located? Please provide your thermostat's power readings. Also, checking your thermostat Energy History will tell you what your thermostat is doing previously.
Check out this guide on how to gather the power readings:
Nest Learning Thermostat and Nest Thermostat E:
Nest Thermostat 2020:
To share a photo, click this link then scroll down to your response and hit reply. Check for the camera icon or click the three horizontal dots to expand the toolbar.
I appreciate your input, @ImNotANestUser.
