07-26-2023 04:50 AM
I own two Nest Thermostats. One of my units recently went dead on me. I plugged it into a cable and it powered back on but only for a short period of time. I then began reading threads that it could be the furnace or the power supply so I thought to plug it directly into my other NEST cradle only to discover is the unit itself that is not holding a charge and not the power supply or furnace. The reason I know this, the other unit plugged in to the malfunctioning units cradle is working just fine.
The unit is only a few years old, so I'm wondering if the battery is just completely depleted - if so, is there a way to change the battery or do I now need to invest in a new unit?
07-31-2023 11:43 PM
Hello gmarkoutsas,
I'm sorry to hear you're having an issue with your Nest Thermostat that won't hold its charge. I'd be happy to take a look at this for you.
The Wi-Fi connection is unstable, the connection between the thermostat and the router has interference, and it may have power issues that have been overlooked for a long time. These are some of the possible reasons why your Nest Thermostat drains its battery. To isolate:
08-03-2023 11:46 PM
Checking back in — how's it going? To better diagnose your thermostat's behavior, please let us know more about it with the questions above so we can move forward.
08-23-2023 06:35 PM
The nest is still malfunctioning. Sometimes it works sometimes it doesn't. Looks like I need to replace it.
08-24-2023 06:13 PM
Now it won't even turn on even when I directly plug it into a charging cord. Is there some kind of warranty on these things. It's not that old.
09-01-2023 09:31 PM
Hi gmarkoutsas,
I know it has been a while, and I'm sorry to hear the issue still persists. Let's sort this out.
Could you please fill out this form with the needed information? A member of our senior support team will be in touch over email to help. Let me know once you're done.
09-04-2023 04:33 PM
We've received your form; thanks for filling it out. If you have questions or concerns in the future, feel free to start a new thread, and we'll be happy to help.
All the best,
11-15-2023 05:01 AM
Hey Mark. I am having a similar problem. I have 2 Nest Thermostats. First one is a 5 wire set up and works fine. Second one is a 2 wire (W1 & RH). The Nest internal battery is only holding a charge for 24 hours. Both have been installed for 8 months and we’re working fine for 7 months. I think the internal battery is bad. I would like a replacement.
11-22-2023 10:05 AM
@Dowro07, thanks for visiting the Google Nest Community, we wanted to look deeper into your case. Please answer the following:
Let's gather power readings of the Nest Thermostat. Follow the steps below:
For the Nest Learning Thermostat and Nest Thermostat E:
For the Nest Thermostat 2020:
Thanks for the help here, Mark and Zoe.
Renz
08-08-2024 01:37 PM
I have 2 cameras that I bought recently and one of my cameras is doing the same it want hold charge. I’ve only had them 2 Weeks and it has died twice
06-27-2025 11:39 AM
I need a Nest thermostat guru to solve my issue. Charged the thermostat. Everything up and running last night. This afternoon, the thermostat light is red. So, I am charging it now. I feel I am missing a programming or Wi-Fi step. The app is of no help to me.
Laura in Cape Coral, FL
01-21-2024 05:28 PM
My nest learning thermostat randomly disconnected from my wifi 2 months ago, will not reconnect or even recognize any network. Now it won't hold a charge either on the base or by USB. The entire unit quit on us on the coldest weekend of the year! Is there a replacement option? We have had this unit for less than a year!
01-25-2024 09:21 AM
Hi TrishaD,
I'm sorry for the trouble this may have caused you. To confirm, in what country are you located? How long did you charge your Nest Learning Thermostat to a USB charger?
05-05-2024 04:27 AM
TrishaD I’m having the same issue
08-25-2024 04:26 PM
Mines doing the same, but the hottest weekend
05-14-2024 02:20 PM
My nest 3nd has been in almost seven years. Recently there was a low battery problem, the USB battery could not be charged, but it did not show a black screen. Do I need to change the battery? Or contact customer service directly? Is there a customer service number?
06-30-2024 11:56 PM
I’m in the same boat one unit works, the other conked out. I regret buying this “smart” device. My AC keeps cycling on and off with no way for me to stop it. Spare me how this saves ANY kind of energy. Reading the non helpful replies to an obvious crappy product makes my blood boil. Will be trashing Google nest on every retail site until this is fixed. Hopefully the contractor who installed this brings me a new unit. Waste of money!!!
08-27-2024 08:20 PM
I also have 2 gen3 nest learning thermostats. About a week ago the upstairs unit stopped working. It sometimes turns on for about 30 seconds and then says it has to shut down because the battery is low. I removed the unit and plugged it into a usb charger for 3-4 hours. When I reattached it to the base it turns on for less than a minute and then shuts down because the battery is low. If I attach it to the base for the other unit I have the same issue. I can attach the downstairs unit to the upstairs base and everything works fine. It seems like the upstairs unit has a bad battery. Both units are about 9 months old. Is there a way to get a replacement unit under warranty?
10-13-2024 12:13 PM
Same problem here but with 2 gen 1 thermostats. Able to get unit back up and running and on line for a few hours after charging via cable. Don’t even know if I have this c wire but- how do I tell? Have had these 10 years plus. Please help.
10-17-2024 05:27 PM
Hello @Lesliep,
Thanks for posting in the community. I apologize for the inconvenience you are having with your Nest thermostat.
I understand you are having issues with the thermostat's battery, but no worries; let's work together on it.
First of all, please share the following information:
Once you share this information, we can gather the right information to make your device work as expected.
Thanks in advance,
Catheryn.
10-29-2024 03:41 PM
Doorbell camera died I took it off the wall and put it to charge. For a couple of hours and it’s still not charged would like to know what’s wrong with it
10-29-2024 03:44 PM
Need some answers
11-04-2024 09:14 AM
I'm having big issues with my nest thermostat it won't charge and is stuck in the on/off loop, I've tried ALL of the trouble shooting tips and nothing works, I need a replacement and it's still in warranty, it's only about 3 months old, thinking of asking for a refund and going to a different manufacturer, I'm unable to turn on my heating or hot water so I want this resolved today
03-06-2025 09:21 AM
I've gone through 2 Nest E's in two days. Both faulty and both not charging.
So far, my only conclusion is these are not well made and unreliable. Should be getting a third on Saturday but not confident it will work.
12-12-2025 06:34 PM
My 2nd Gen battery will only hold a charge for a few hours at a time when charged with the cable. We all just want to know. Can the internal battery can be replaced? Please answer that simple question for 2nd & 3rd Gen Nest thermostat.
01-23-2026 07:56 PM
I hate this thing & want it replaced with a new one that will hold its charge! It’s about to be an ice storm & we have no heat thanks to Google Nest!!!!!! My husband is 81 & in poor health & I just want my old reliable thermostat back.
