12-09-2022 08:28 PM
My previous thermostat did not have an O/B wire, so I don’t have anything connected in that slot for my new Nest. My heat pump is blowing cold when it should be blowing heat. From reading online, it looks like I need to go to settings and go to the thermostat and change from O over to B. However, I can’t find this option on my first Gen Nest. Does anyone know how to do that?
12-14-2022 10:52 AM
Sorry for the trouble. I wanted to follow up and see if I could be of any help. I found an article that has more details. Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
12-18-2022 07:42 AM
Hello Andrew01,
12-18-2022 07:03 PM
Thanks for checking. I’m thinking it isn’t compatible with my system. I couldn’t figure it out.
12-21-2022 01:24 PM
It would help a lot if you could check the compatibility. Open this link to have a detailed info.
Hope this helps.
Dan
12-24-2022 01:28 PM
Dan
12-25-2022 01:40 PM
Hello everyone,
Dan
