Reset camera after already used
mackbmodel
How do you reset camera after already used it it doesn't want to reset
mackbmodel
Anyone know how else to reset camera other then pinhole
@mackbmodel
My experience is that it is sometimes tricky to do a pinhole reset on an electronic device using a paper clip; I've sometimes had to try several times and hold down the reset pin longer than documented.
For some cameras, you can do a reset from the Google Nest app or Google Home app if the camera is accessible from the app.
https://support.google.com/googlenest/answer/9252162?hl=en
Dan_A
Hello everyone,
@janthadeus, @MplsCustomer, thanks for the help.
@mackbmodel, I wanted to follow up and see if you still need help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
Dan
janthadeus
I just wanted to jump in real fast to see if you saw MplsCustomer's reply and to see if you still needed some help on this or if you were able to get it sorted out. If you are still needing some help, just let us know and we'll be happy to continue helping.
I appreciate the help here, MplsCustomer.
Dan_A
Dan
