08-19-2025 06:07 PM
Nest Rush Hour automatically adjusts the current temperature by 3 to 4 degrees based on the current temperature setting. This adjustment should be based, or consider, the current outside temperature.
Case: my thermostat is set at 80 degrees during the day--August in Texas. The auto adjustment set the thermostat to 85 degrees. This is not a safe temperature for elderly or pets.
Recommendation: make adjustments based on outside temp. Of course, Nest and energy companies track usage hourly. There should be data for use in determining the Rush Hour degree adjustment.
08-20-2025
03:08 PM
- last edited on
08-22-2025
07:10 PM
by
AndersC
I see your point—automatically adjusting the thermostat by 3 to 4 degrees without considering the outside temperature can create uncomfortable or even unsafe indoor conditions. A better system would factor in the current outdoor temperature to make smarter adjustments. For example, extreme heat or cold outside should influence how much the thermostat changes. You can find more insights and tips about energy-efficient thermostat settings here: *** This approach would help save energy while keeping indoor conditions safe and comfortable.
08-22-2025 08:09 PM - edited 08-22-2025 08:10 PM
Hi @Jackster,
Thank you for posting in the community and sharing your experience with the Rush Hour Rewards program, where your Nest Thermostat's auto-adjustment sets to 85 degrees, which creates an unsafe temperature for elderly people or pets.
I also appreciate your recommendation to make adjustments based on the outside temperature, using the data that determines the Rush Hour degree adjustment. I understand this option may be useful, considering your needs and the needs of all Nest users. We're always looking for ways to improve, and we appreciate your feedback to continue improving our products and meeting your needs.
Anders
