08-21-2025 05:37 AM
I have some aqara temperature/humidity sensors added to my Google Home devices. These can not display the temperature on the nest hub even if they work perfectly in Google Home app.
Asking assistant for the temperature in a room gives me the correct temperature by voice, but the screen shows a screen with no temperature where the value ring is just loading forever.
Asking for humidity shows a a screen with the correct value as expected.
It might also be related, all temperature sensors show up in the nest hub as "Refer...0" when manually clicking through rooms in the nest hub.
08-21-2025 05:47 AM
It sounds like your Nest Hub is having trouble fully integrating the Aqara temperature sensors visually, even though Google Assistant can access the data by voice. This usually happens when a third-party sensor isn’t fully recognized for display on the Nest Hub screen.
A few things you could try:
Check device naming – Make sure the sensors have simple, unique names in the Google Home app. Sometimes long or unusual names cause display issues.
Reassign rooms – Remove the sensor from its current room and re-add it to the correct room in Google Home.
Force sync – In the Google Home app, remove the sensor and re-add it, or use the “Sync devices” option in the Assistant settings.
Firmware & app updates – Ensure both your Nest Hub and the Aqara sensors have the latest updates.
If none of these work, it may be a limitation in how Nest Hub handles third-party temperature sensors visually. Voice queries work because the Assistant pulls the data directly, but the screen may not support rendering it from these devices yet.
Some users have reported that renaming the sensor to something very short (like “Living Temp”) sometimes makes the ring display correctly.
08-21-2025 07:07 AM
Hi! I need to revise the information in my question.. I copied it from an older question but see now that its not a 100% correct for me...
I CANT ask google assistant for the Temperature... and cant see it on the screen either. But when I ask GA for the humidity it can answer...
And in the Google home app I see both temp and Hum....
08-28-2025 07:30 PM
Hi Therapyman,
Thanks for posting in the community and to @ayla74108 for jumping in! I understand that your Aqara temperature sensors are not displaying their values on your Google Nest Hub, despite working correctly in the Google Home app and with voice commands. It sounds like the Nest Hub shows a continuous loading ring for the temperature and mislabels the sensors as "Refer...0" when you navigate through the rooms. I'd be glad to share the information you need!
I'd like to recommend that you check with your sensor manufacturer to confirm the device specifications. I also reviewed multiple threads online, and it seems that other users are experiencing the same issue. In the meantime, you can share feedback through the Google Home app.
Please feel free to post any further questions you have in this forum.
Juan
