'We couldn't authenticate your Chromecast"
RLB70514
Within last couple days, unable to cast (Netflix). After factory reset the Chromecast, seems all is good. Device found and select to connect. But, keep getting "... couldn't authenticate your Chromecast"
70 REPLIES 70
Pono
Stesso problema , che si fa??
ChrisP-y
Fix wen?
ChrisP-y
There is a detailed Reddit thread with workarounds here: https://www.reddit.com/r/Chromecast/s/X1FNsdeSQG
jcbmail
Same issue here.  I rebooted and not able  solve.
shaan_sam
Same issue "can't authenticate..." with android phone and unable to connect with wifi via iPhone setup it's been more than 72 hrs unable to get hold of Google support team this is really frustrating
Raarriol
Same issue. I changed my internet provider, so I reset my chromecast to factory settings. No longer working after that.
Ranga90
Has anyone got a solution yet on how to fix if you've already reset it
suz4
No luck yet. Not everyone has the money to replace with a new device. For me 160 Aussie dollars
Nunyabisnes
I will never buy another google device after this, we've been abandoned. Google aren't interested in this problem. Probably because it's planned obsolescence. They want us to buy the latest device.
carcarcar
same issue here
Chantalfeeney
Any updates
manikspn2025
No updates so far , also issue still persist , no help from Google on tickets as well.
not sure if google don't want us to use the 5 or 10 year old devices.
F-3000
Per news source, Google has began distributing update that fixes Chromecast 2 and Chromecast Audio. (Found the news by googling "chromecast", by the way.) But those who have reset their device must wait longer for a fix.
For those who are wondering why Google doesn't respond to support requests, my guess is that their support is currently completely clogged because of the issue with Chromecasts.
pdude
I couldn't cast from Netflix and so I factory reset my Chromecast now when trying add the device in the Google Home app I'm getting:
We couldn't authenticate your Chromecast. Please visit support.google.com/chromecast for help troubleshooting this issue.
F-3000
Attention!
I had earlier reconnected Chromecast to Google Home (Android) by setting my phone's date to 7.3.2025 (works as long as it's earlier than 9.3.2025). Just short ago I decided to check what happens when I start Chromecast, and behold! It instantly updated itself, and now it works just as supposed to!
In my case, strange is that Chromecast still doesn't indicate it would be connected to a network (stopped after resetting), yet it works anyway.
So, just set your phone's date to earlier than 9.3.2025 and try connecting with Google Home. After connection is made, wait for Chromecast to update itself.
jmetzner
thank you thank you thank you!! have been fighting with this for days....I even ordered another device (non chromcast which is no longer made(???)) and it didnt work either until I tried your trick! you're awesome.
F-3000
You're welcome! I just hope more people would read this thread, instead of continue complaining.
Yes, Chromecast is no longer made. Its successor is Google TV, which is more expensive device, nearly thrice the price of what Chromecast was.
Bangore
Mine is working again, just reboot your chromecast and when it starts wait for the update, it should be ready to cast after that
F-3000
If no reset is done, or reconnected after reset, then yes, this should work.
BliTzer
When the 4 number & letter verification appears on TV screen to authenticate, another message will pop up on all devices with google home saying "could not authenticate your Chromecast" & you can't get past that. It starts a loop using same message. Can't even reboot from app as it will not read the device. Before google posted the message do not reset, I followed directions which said do a factory reset.
If you have a 1st Gen Chromecast it works, as I have two that I'm glad i kept. Just hook it up, DONT RESET, i used my original home. It will say offline, but it's not, just click cast screen & it will mirror whatever is on your device.
Bangore
No I reseted it, reboot it all possible since before yesterday but now it's working. Have a 2nd gen FYI
Been123
Do we have any update on this issue, facing problem since last week
Been123
Do we have any solution for Chromecast authentication issue
divyadevirs
What to do with this?
Please someone respond
Ankit5
I am also facing same issue.pls suggest Chromecast 2nd gen .I also did factory reset.unable to authenticate
Nunyabisnes
Google hs abandoned us. There is only a problem, not a solution. Never purchase a physical product off them again. I feel like this is a case of  planned obsolescence.
Either planned obsolescence, or someone got very, very sloppy.
There is a solution mentioned in this thread.
On Google's end, it's not an easy thing to fix, as they need to create a solution that works "indefinitely" without creating a security hole in Google Home, and has as small impact on the app as possible. And since Google hasn't made it public about what went wrong, they seem to be embarrassed of it.
F-3000
Google has issued an update for Google Home that should help with connecting to resetted Chromecast. Update Google Home to version 3.30.1.6 on Android or 3.30.106 [Wide] on iOS.
Dorabella
The Google home update isn't showing in my appstore?
F-3000
Probably takes some time to show up, as updates usually are distributed in delayed manner, so that servers wont choke up. I've sometimes received updates that are released months before, even though I've manually checked updates just week ago.
Ankit5
Issue resolved.chromecast indian products
