3 weeks ago
As the title says, my Nest Protect A11 battery smoke and co2 detectors is beeping once every minute. Power light is not illuminated, no voice audio plays, and pressing the button doesn't do anything.
Any idea what's up?
3 weeks ago
We don't have Nest Protects, but this Help topic says:
"Low battery: Protect will sound one chirp every 60 seconds until you replace the batteries."
3 weeks ago
Thank you for the reply. I saw that solution too, but it doesn't coincide with previous times that the batteries were low. Previously the Nest would announce, rather loudly, "Battery low, please replace". It would do this every minute or so. The LED light would also be illuminated yellow. This time, there is no voice announcement nor LED light.
So I'm confused if that were the case, why the warning is so different.
3 weeks ago
Since your symptoms do not match any of those described in Google Nest's Help topic, maybe it's worth calling Support and asking them to explain what it means. They SHOULD be able to look up their own error indicators and tell you what it means.
