04-10-2022 07:42 PM
What should a 1.4 model have for voltage? New NT says good but at 3.1v for days now. Goes offline daily. Okay if I unplug and reinstall at base.
04-10-2022 11:01 PM
How do you have it wired?
The Google Nest Thermostat uses replaceable Alkaline batteries and depending on how it wired a C wire might be required.
04-18-2022 02:01 PM
Hi SCF,
Thanks for reaching out and we're sorry for the delay.
I'd like to jump in here and check how it's going with your Nest Thermostat. Are you still having the same issue with the network connectivity?
Let us know by replying to this thread.
Ryan
04-18-2022 02:08 PM
Still goes "offline" once daily. I moved it 2.4 from 5ghz to see if that helps. Router reboot fixes it. Odd that the router never sees it disconnect. It is 10 feet away and line of site. No other connection issue on my network.
04-23-2022 05:40 PM
Hey SCF,
Thanks for the update and we're sorry for the delayed response.
By connecting it to the 2.4Ghz network, it will have a much more stable connection as this type of signal provides a larger diameter of signals.
We'll observe the behavior for the next 3 days and let us know how it goes.
Ryan
04-26-2022 05:06 PM
Hey SCF,
Ryan
04-30-2022 05:51 PM
Have a great day.
Ryan
04-11-2022 03:38 AM
I do have the C wire installed. R,Y,W,G,C no jumpers. No e codes asking for it at setup.12 year old Gordon furnace gas forced air with AC.
04-11-2022 05:03 PM
Offline again. Network is connected and a strong signal. No other errors. Did see something about go. Server
04-11-2022 05:05 PM
Time to return to Amazon?! Two weeks worked maybe two days.
