3 Nest Learning thermostats not connecting to same home.
AP4
I was able to individually connect the nest thermostats to different homes but once I try and connect an additional thermostat to the same home of another, it will not work. The error message says it is not able to connect with the assisting thermostat. Also, is there a way to connect the thermostats to the same home without using another one's help?
Jhonleanmel
Hi AP4,
Thanks for posting ― let's get this sorted out.
Give these steps a try:
  1. Make sure that the nearby thermostat's display is on so it weaves your additional Nest Thermostat while it's display is awake/on.
  2. If issue persists, try to setup your new Nest Thermostat on a separate Home structure.
Keep us posted.
Mel
Hi AP4,
I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
Mel
Hi AP4,
Mel
