07-16-2023 02:32 PM
I recently moved in and the house came with 1st generation thermostat. I added it to my google home app but I had to do the factory reset and add it to the app. Everything went good but when I turn on the ac to cool (70) it won’t blow any cold air just air. Like I said it worked perfectly before I did the factory reset and put it under my app.
07-20-2023 10:26 AM
Hi Fmayorga12,
Thanks for posting here in the Community forum, and I'm sorry to hear about the situation. Please answer the following:
Also, please collect the power readings of your Nest Learning Thermostat power readings from Settings > Technical Info > Power and list down the following:
07-23-2023 01:00 PM
Chiming in — I just want to check if you managed to see the response above. Please share with us the needed information, as it will help us to move forward.
I appreciate the help, Zoe.
07-24-2023 02:58 PM
Hey Fmayorga12,
I'm just checking in to make sure that you've seen our response. Please let us know if you have any other questions or concerns, as I'll be locking this thread in 24 hours.
07-24-2023 10:35 PM
As of right now I have an hvac come out to see it. Not sure what happened exactly after I did the factory reset on it. I shouldn’t have done the factory reset on it and it would’ve stayed working.
07-25-2023 08:54 AM
Hello there,
Thanks for keeping us in the loop. We'll keep this thread open while an HVAC technician checks your AC, but please be advised that as Community Specialists, we occasionally do a bit of housekeeping to keep the conversations in our community fresh and relevant. This includes locking threads after a period of inactivity.
Kind regards,
07-28-2023 09:49 AM
Hello Fmayorga12,
07-28-2023 09:58 AM
Thank you for checking in but it seems like the problem is my HVAC unit and not the thermostat.
07-28-2023 10:06 AM
Hi there Fmayorga12,
Thanks for getting back on us, and I appreciate you checking in on that. It looks like we can consider this one complete, so I will be locking this in 24 hours if we don't hear back from you again. Feel free to start a new thread, and we'll be happy to help.
All the best,
