Adding C Wire Power Adapter
JimPNY
I am adding a C Wire adapter to my Nest Thermostat 2020. Can you confirm this wiring configuration for a 2 wire gas/heat only system: White wire with black stripe from adapter to "C" terminal, White wire from furnace to "W" terminal, White wire (no stripe) from adapter to "R" terminal and Red wire from furnace to "R" terminal as well. The "R" terminal will have 2 wires inserted. Is this correct? Thanks.
Hey JimPNY,
Apologies for the late reply. I wanted to follow up and ensure you are good to go. Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
Hey JimPNY,
Hey JimPNY,
