Air Conditioner doesn't turn on until Nest Thermostat sense me approaching
rgaila
Original Poster: Jack Fleming
My air conditioner does not kick on unless my Nest Thermostat senses me approaching. It is not connected to WiFi, so that has nothing to do with it. I have another nest thermostat on a downstairs unit and I have no issues with it. What could be the problem with this thermostat? It is less than a week old.
MikeB
Jack F - I simply went to Settings, and turned off the "Home/Away Assist" option. Haven't had an issue since...
JackF
I will try that. It's weird, I took back the other thermostat and had it replaced and it worked fine for about a week or two. After that, it reverted back to doing this. I'll keep you posted as to whether or not this works. Thank you
JackF
Still having the same issue after trying this.
