04-22-2022 08:18 AM
Hi, we just moved into our home with a Nest System. I can't find or tell if the system has temperature sensors. How can I validate that? Are they required or does the thermostat itself have a sensor?
04-22-2022 06:56 PM
The Nest Temperature Sensors are optional and are not required. They also only work with the Nest Learning Thermostat, 3rd Gen, and the Nest Thermostat E. THey are also only available in the US, Canada, and Mexico.
04-26-2022 08:11 PM
Thanks for responding, Patrick_Caezza.
SunnySnow, I wanted to ensure everything is good here. I also suggest that you check this link to know more information about our Nest Temperature Sensor: https://bit.ly/3hzLbli
Should you need more information as well on our Nest themostats, check this out: https://bit.ly/3h7gV0P
Hope these will help.
Melba
04-29-2022 08:16 PM
Hi SunnySnow,
Checking back in — still have some questions about our Nest Temperature Sensors or our Nest thermostat devices?
Melba
05-01-2022 07:59 PM
No, I understand now. Thank you!
05-03-2022 12:21 AM
Hey SunnySnow,
Gotcha — thanks for responding. If that is the case, I'll be locking this thread now. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community.
Melba
