Hello Stacikirk512,
Thank you for reaching out with your question about activating the aux heat on your Nest Thermostat without Wi-Fi. If your Nest Thermostat is not connected to Wi-Fi, you can still manually activate the auxiliary (aux) heat.
Here's how you can do it:
- Look for the physical thermostat on your wall.
- Use the thermostat's interface to navigate to the temperature display. This is usually done by turning the outer ring or pressing on the display until you reach the Heat setting.
- Increase the target temperature higher than the current room temperature. This will signal the thermostat to engage the auxiliary heat.
- After adjusting the temperature, give it some time. The thermostat will recognize the need for auxiliary heat and activate it if necessary.
If you're still having trouble, let us know—we're here to help!
