02-22-2022 10:59 AM
I replaced the two AAA batteries that came with the Thermostat when it reported that the batteries were low. I installed alkaline not being aware that the originals were rechargeable Lithium ! I have a 'C; wire installed delivering 24VAC so do I still need the batteries at all and if I do then should I buy a new pair of rechargeable or just go with the alkaline ?
Thanks for you considerations
jim
02-22-2022 04:10 PM
This will depend on which thermostat you have. However, if you were able to replace them it is probably the "Nest Thermostat".
The batteries assist when there is a power outage, low power, or the furnace is turned off at the unit or the circuit breaker. You should ensure it has batteries.
https://support.google.com/googlenest/answer/9297548
https://support.google.com/googlenest/answer/10119271
02-22-2022 04:10 PM
02-23-2022 06:27 AM
Yes it is the basic Thermostat. So the type of battery doesn't matter then. Google supplies rechargeable as a curtesy to the customer I guess so we wouldn't have to keep changing them. Good to know.
Thanks
02-27-2022 02:48 PM
Hey everyone,
I just wanted to follow up and see if you're still in need of help? Please let me know, as I would be happy to answer any questions you may have.
Thank you for always helping us, sporfrog.
Ryan
02-27-2022 07:26 PM
Going through set up for gen. 3 smart thermostat and accidentally selected fuel fuel. Now the system is locked in a loop and will not allow to change my selection and tells me to call a installer. What do I need to do to clear the system and start over.
02-27-2022 07:32 PM
Should read duel fuel.
03-01-2022 12:49 PM
Hi 40danceman5,
Thanks for reaching out and we're sorry for the delay.
You could check the equipment selection in settings > select equipment > choose the right heat type and source. Try to test the equipment as well.
Let me know how it goes by replying to this thread.
Ryan
03-02-2022 07:51 AM
Hey Ryan Thanks. I attempted a power test after installing a 'C' wire and relocating my WIFI extender to the thermostat's proximity but my Canadian model 1.4 (mirror face) doesn't seem to have that programming. Probably present in the "E" types and "Learning" models. I run the test but it flips back to the initial screen. As for batteries I have replaced the Alkaline with rechargeable Lithium as supplied when new. No point in trying to rewrite the book ! It seems to be functioning now as advertised but I'm not relaxing just yet.
JIm
07-18-2022 01:28 PM
Hey JayDev,
Since this thread hasn't had activity in a while, we're going to close it to keep content fresh. You could check out this link to know more about Nest Thermostat battery.
Hope this helps!
Kind regards,
Ryan
