05-13-2024 05:00 PM
A couple years ago I connected the C wire (I thought) today it says battery very low replace. If my C wire is connected it should not have a low battery right. When I look at connected wires it shows Y-W-G-R, also it says unable to test and nest power connector not detected g.co/nest/m25. any thoughts
05-16-2024 04:59 PM
Hi @mrelmo,
I understand your frustration with the Nest thermostat. I apologize for the trouble you're experiencing. There are a couple of possibilities for why your Nest thermostat is showing a low battery warning even though you believe a C wire is connected. Let's troubleshoot:
C Wire Connection Verification:
App Information:
Nest Power Connector:
Troubleshooting Steps:
If the issue persists to assist you better, we'll need some additional information. Here's the contact us form once you've completed the form, please let me know.
Brandon
05-16-2024 06:26 PM
I will follow your directions tomorrow and update you, I believe but not sure when I installed the nest there was no c-wire so in setup I just confirmed that I was using the white, green, yellow and red. So I think I need to go back in some how and reenter the wires that I am now using. Which would now be 5 wires.
05-17-2024 12:00 PM
OK upon further review I have a C-wire on the nest but nothing on the furnace, so I have to run a new 5 wire from the nest to the furnace, sorry for not having complete information. When I get this done I will post the results as of now thank you for the help up to this point.
05-19-2024 10:34 AM
Hi @mrelmo,
Thanks for letting me know that information.
Safety First: Make sure to turn off the power to your HVAC system before working with any electrical wiring.
Professional Help: Running new wires in your home can be complex, especially if you're unfamiliar with electrical work. If you're not comfortable doing it yourself, consider hiring a pro electrician to ensure it's done safely and correctly.
I hope it works and if for some reason you're still getting the same issue you can use contact us form or let me know.
Brandon.
