Battery is low
Halbrand
I posted a week ago. I missed the replies. Just reporting back my thermostat is not holding the charge. It keeps disconnecting from my WiFi network. Need help. TIA
MrVacca
Silver Product Expert
does the app say that you need to get a power connector to maintain sufficient power to stay connected?
aatienza
Hey Halbrand,
Thanks for getting back to us. A few questions: when was it installed? Do you have more than one thermostat? If yes, does the issue show up on the other thermostats too? When did the issue start? Also, what country are you located in?
I appreciate the help, MrVacca.
Archie
aatienza
Archie
aatienza
Hello there,
Archie
