Battery replacement
HomeOwner1
My nest says replace battery and I need to remove it from the plate. How do I do that?? The video I saw  he just pulled it off and I am unable to do that. I need help
Just grasp it firmly and pull it straight off.
They can seem to be stuck on the first time or two that you try and remove it
MelbaDT
Thanks for helping, Patrick_Caezza.
HomeOwner1, how's it going? Were you able to change the battery of your thermostat by following Patrick's advice above?
Melba
MelbaDT
Hey HomeOwner1,
Checking back in — how's it going with your thermostat now? Let us know if you still need help with it by replying to this thread.
Melba
MelbaDT
We haven't heard from you in a while so we'll be locking this thread if there is no update within the day. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community.
Melba
