01-13-2022 10:39 AM
My nest heat link (~1 year old) has suddenly stopped working - the thermostat can’t connect the the heat link (h71 error). There are no lights on the heat link so I can’t do a reset, etc. It looks like it might be a common/known issue. Can anyone help? Thanks!
01-17-2022 03:46 AM
Hi there. Thanks for reaching out. I'll do my best to get this sorted for you as soon as possible.
Here are some helpful troubleshooting steps:
Press the button on the Heat Link and check if you have any lights on it
Check if the circuit breakers and the switches are set to on
Turn them off and then back on
Press on the button again and check for LEDs
Could you also help me with some answers to these questions?
How many zones ( thermostats ) are present in the setup?
01-20-2022 03:59 AM
Hello again. Just checking in. How's it going with your Heat Link?
01-27-2022 06:38 AM
Since you haven't replied yet, I'll have to lock this thread. Feel free to open a new one if you still need any help.
