Burnham Alpine Boiler and C Wire for Nest
johnwatertown
I once connected a Nest smart thermostat to a gas fired boiler by running a new 5 (?) strand wire from the T-stat to the boiler and attaching all the colored wires in the corresponding colored slots. Easy!
Now in a different house I want to do the same thing, but my problem isn't with snaking the wire through the wall, but not knowing where to connect within my Alpine ALP080B boiler.  I have a Red and White wire connecting my Honeywell thermostat to my heat-only system. A green wire in that three-strand bundle is not used; it's unattached. The three-strand T-stat wire runs to an electrical junction box in the cellar where the T-stat Red and Green wires are linked by a wire connector with the Red line from the boiler. Another connector links the White wires from the T-stat and Boiler. The wire from the boiler has only a Red and White wire.
Those Red and White wires at the boiler are attached to the slots labeled "Heating T-Stat" in the boiler.
So what do I do? I would run a new 3-strand wire from the Nest thermostat, bypass the junction box, and go directly to the boiler, but I don't know where to put that common wire. There is no place marked "C" or "Common" on the boiler. Surely someone else has these very common Alpine boilers? Nest has a power connector but even that seems like it needs a place to attach to, which   the Alpine seems to lack. Any help would be appreciated. Wish I could post photos. Thanks in advance.
Derickf
Hi @johnwatertown,
Thanks for reaching out to the Google Nest Community. I can understand that you want to install the thermostat by yourself; I'll be more than glad to help you.
Based on the situation, it is important that we check the current wiring to determine if it is possible to provide you with instructions about how to install your Nest Thermostat. In order to receive further assistance, please fill out this form with all the necessary information, like the thread title or link and your username in the community. Once you've completed the form, let me know. Someone from my team will contact you shortly to help.
In the meantime you can take a look at the following article: Identify a thermostat wire.
I’ll be waiting for your reply.
Derick.
