04-13-2023 08:23 AM - edited 04-14-2023 05:27 AM
I have 2 basic two wire zones 1 upstairs and one on first floor. Both have only R and W terminals
I have installed the power connector on one of the zones with the additional transformer.
Can I use the same transformer for another power connector like in below diagram for the upstairs nest?
04-15-2023 07:07 AM
Thanks! Yes. Remove the jumper first. Thanks!
04-14-2023 08:15 PM
Yes, you can.
Be sure to remove the jumper on the power connector.
04-15-2023 07:07 AM
04-17-2023 04:25 PM
Thanks for reaching out and for being a step ahead of us. How's your Nest Power Connector? Is it already installed properly? Please let me know if you still have questions or concerns, as I'll be willing to assist you from here.
04-20-2023 04:34 PM
Hi abushman,
04-21-2023 04:48 AM
Just wanted to confirm 1 transformer power (2) power connectors
04-21-2023 01:21 PM
Thanks for getting back to us. Yes, you may install two Nest Power Connectors for one 24VAC/20 VA transformer as long as it can support them. You can check this article on how you can install them for your system.
Feel free to message again if you have questions. We're here to help.
Thanks for stopping by, @Patrick_Caezza and Jenelyn.
04-24-2023 01:59 PM
Hey abushman,
I wanted to check in. Please let me know if you have any questions from here, as I would be happy to assist, and answer any you may have.
04-25-2023 11:53 AM
