Compatability
jjow
I have an apartment with baseboard heaters. Is my system compatible with Nest? I cant seem to share images but the link is below.
https://drive.google.com/file/d/1gvTfOrEoweEEQQG8Yh9YHtYCUUhmPpE9/view?usp=drive_link
Thank You,
Josh
zoeuvre
Hi jjow,
Thanks for posting here in the Community forum and for showing interest in our Nest Thermostats. Fortunately, your thermostat wires are compatible with our Nest Learning Thermostat 3rd generation or Nest Thermostat E and should be wired to the Nest Learning Thermostat and Nest Thermostat E's base as follows:
  • W to W1
  • RH to RH or R
Also, here's a guide for the installation and setup of Nest Learning Thermostat 3rd generation and Nest Thermostat E
Let us know if you have any other questions.
