Compatible Nest thermostat for York Thermostat Model no. 1BCE03686LCD
herbert12
Your system uses a proprietary interface that is not compatible with any of the Nest Thermsotats
8 REPLIES 8
Ryan_G
Hey herbert12,
Thanks for reaching out here in the community.
I'd like to jump in here and check if you've seen Patrick_Caezza's response. As Patrick's mentioned, your system uses a proprietary wiring configuration and it is not compatible with Nest thermostat.
You could check this link to know more about system compatibility with Nest thermostat.
Thanks for your help, Patrick.
Ryan
Is this 24V ?
I mean York thermostat model 1BCE03686LCD is it 24V?
herbert12
Its 5V
Marwan
Thanks.
Where is the concern in installation, as your york has 4 wires and should workً with nest!!
MelbaDT
Thanks for your responses, Marwan.
Google Nest thermostats are designed to work with most 24 V systems. To know more about compatibility, please check on this link: https://bit.ly/3buNFQC or our Compatibility Checker.
Melba
MelbaDT
We haven't heard from you in a while so we'll be locking this thread if there is no update within the day. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community.
Melba
