07-10-2022 11:09 AM
Need help with connecting wires to Nest 3rd Generation Learning Thermostat. Have tried a few options but can't even get it to turn on.
07-14-2022 11:45 PM
Hey kdiane39,
Thanks for the photo of your original thermostat wires and for reaching out to the Google Nest Community.
A few questions — are you getting message or a code on your Nest Learning Thermostat? Could you share a photo of how you wired it? Also, are you comfortable tracing that blue B wire to your HVAC's control board if this is a common wire or indeed for your heat pump? You may also refer to your current thermostat's manual if you have it.
Melba
07-18-2022 06:48 PM
Checking back in — how's it going? Still need help with your thermostat?
Melba
07-19-2022 06:56 PM
Melba
