Connecting to a heat pump
pfenton42
I have a Lennox AC/Heat pump system and a Honeywell thermostat.  Not sure where to make the connections to the Nest thermostat.  Existing connections are as follows (I don't know how to attach a photo):
Left side:
S = Red
S = White (There are two S terminals on the left)
Y = Yellow
G = Green
C = Blue
Right side:
L/A (A) = Open
O/B = Orange
Aux (W2) = White
E = Open
Aux (W) = Open
K = Open
R = Red
Give this wiring a try.
Red - S - not used
White - S - not used
Yellow - Y to Y1
Green - G to G
Blue - C to C
Orange - O/B to OB
White - AUX to W2/AUX
Red - R to Rc
The S terminals are for an outdoor temperature sensor that the Nest doesn't use.
6 REPLIES 6
Post a picture of the original thermostat's wiring here
Red - S - not used
Yellow - Y to Y1
Green - G to G
Blue - C to C
Orange - O/B to OB
Red - R to Rc
Ryan_G
Thanks for reaching out here at the Google Nest Community.
I'd like to jump in here and check how it's going with your Nest thermostat, pfenton42? If you have further questions, let us know by replying to this thread.
Ryan
MelbaDT
I haven't heard from you in a while so I'll be locking this thread if there is no update within the day. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community.
Melba
pfenton42
Thank you, Patrick!  😁
