Connection help.
Brandyjr
 can I connect a nest thermostat?  Need help.
Does your system have a modulating gas valve? The orange wire connected to the V terminal is what controls the valve and none of the Nest are compatible with it. You can look in the furnace/air handler and see if the orange wire is connected to a V terminal. If it isn't then you can use a Nest Thermostat.
EdwardT
@Patrick_Caezza, thanks for the help!
@Brandyjr, how's it going with your Nest Thermostat? Still need our help?
Edward
EdwardT
Hi Brandyjr,
Edward
EdwardT
Hi Brandyjr,
Just checking in to make sure that you've seen our response. Please let us know if you have any other questions or concerns as I will be locking this in 24 hours.
Edward
