Constant restarts and battery drain
Jamesg
I've had the nest since early 2020. Now my device loses wifi, restarts every 15 to 20 minutes, and batteries are drained after about 36 hours. Tech support suggests installing Nest Power Connector.  Anyone else have experience like this?
9 REPLIES 9
Ashepherdson
Whats the current voltage?  If its always running low then that could have killed the battery life for sure.  With a C wire or the power connector you wouldnt have this issue, however if the battery is already gone bad then it may be too late.
Jamesg
The battery voltage is 3.196V, 977mOhm
Under the power info option it reads Vin: 30.472
Lin 259(S)
PS: Y-385 YS-259. YP-2, W-10
If you have the Google Nest Thermostat (2020) and don't have a C wire connected, it means you need to connect one, and the Nest Power Connector is the easiest way if you don't have a spare wire.
How do you have it wired?
Jeran
Hey there Jamesg,
I'm just checking up on this thread, did you have any more questions or need any additional help?
Thank you for helping out on this thread, Ashepherdson and Patrick_Caezza!
Jeran
Jamesg
Hey Jeran.
Thanks for reaching out
I installed the nest power connector but the thermostat is now stuck in cyclical restarts. I have no idea what to do next
Jeran
Hiya Jamesg,
No problem at all, I would encourage you to check out the troubleshooting section of this article. Go ahead and try the different steps, and if the problem persists, please let us know.
Jeran
EdwardT
Hey Jamesg,
Edward
EdwardT
Hey Jamesg,
Edward
Jeran
Hey there Jamesg,
Did you have any more questions or need any additional help?
Thank you,
Jeran
