10-13-2023 01:25 PM
So I have a really old wood furnace that heats my garage and the apartment above it. I currently have a switch (not smart) to turn the blower on and off. I'm looking for a solution to make this smart. I want to be able to have the blower turn on/off at a certain temperature in the apartment. I'm not sure if a smart thermostat can be hooked up to a blower only? Should I just use a smart switch and a smart thermometer? Any advice would be appreciated.
10-16-2023 02:24 PM
Hi R21A,
Thanks for posting here in the Community forum and for showing interest in our Nest Thermostats.
Are you located in North America or Europe? To help us get a better picture of your system's compatibility with our Nest Thermostat, do you mind sharing a photo of how your current thermostat is wired? You may also use our Compatibility Checker to help you determine if a Nest thermostat is compatible with your heating and cooling system.
Keep us posted.
