Cooling: Does the fan need to run constantly?
Wyndolynn2
How do I keep this Nest Learning Thermostat cooling? It’s set at 71 degrees but it’s been 76-78 degrees in this house since 6pm, it’s 6am now and only seems to cool a little when I select the fan option. Once the fan stopsafter 30 minutes, it goes back to 76 and never reaches 71. I’ve turned off all home/away and Eco settings. I do not have anything in the schedule. It’s the weekend and I’m home and can’t get cool.
6 REPLIES 6
How do you have the thermostat wired? is there a C wire installed?
EdwardT
@Patrick, thanks for the help!
@Wyndolynn2, How's it going with your Nest Thermostat? Still need our help?
Edward
AllSmiles
Hello.  I'm having the exact same problem.  I have a C wire.  Temps are getting hotter.  We are in the high 90's.  A few days ago, I noticed that it was taking extra long for the house to get cool.  I notice that my house remains in Cooling Stage 2.  Yesterday, it ran for 18 HOURS in Cooling Stage 2.  If it weren't for the cooler temperatures of the night, I'm not sure if it ever would've reached the desired temp.
EdwardT
Hi AllSmiles,
Thanks for letting us know. I'm sorry to hear that you're also having the same issue. Could you tell us how your Nest Thermostat is wired? Also, please check the power readings of your Nest Thermostat by going to Settings > Technical Info > Power.
Edward
EdwardT
Hi AllSmiles,
Edward
aatienza
Hey AllSmiles,
Appreciate the help, Edward. Just checking in to make sure that you've seen our responses. Please let me know if you have other questions or concerns as I will be locking this in 24 hours if I won't hear back from you again. Feel free to start a new thread and we'll be happy to help.
Archie
