Cooling instead of heat.
Jconnell65
I installed a Nest Leaning Thermostat last week. We have had ac on since. Now we need heat. I have reset. And have changed from O to B still no heat. Photos to show factory, Nest. Any help would be great. Thanks.
13 REPLIES 13
Jconnell65
this a closer pic
Nirav
Your RED wire goes in Rh not in Rc.
Jconnell65
That didn't do it either. Just putting Cpi back on. Mess with it when I find more info. Every way I had it should of worked.
It doesn't matter but the Rc terminal is preferred.
Give this a try
White - W to W2/AUX (set as AUX heat)
Yellow - Y to Y1
Green - G to G
Red - R to Rc (jumper to R not needed)
Blue - B to OB (you will have to change the valve setting)
Brown - C to C
Because your system uses the B wire for the reversing valve relay you have to change its setting.
Nest Learning Thermostat
  1.  On your thermostat, go to Settings.
  2. Select Equipment.
  3. Select Continue > Continue.
  4. Select Heat Pump.
  5. The Nest Thermostat defaults to an O setting for heat pumps.
    • If the O option is highlighted, select B.
  6. To make sure the issue is resolved, test your heating and cooling again.
MelbaDT
Thanks for your detailed responses as always, Patrick_Caezza.
Jconnell65, I'm chiming in to make sure everything is covered here. How's your thermostat now?
Melba
I haven't installed it back yet. I'm going to do it Saturday. And try Patrick's way. Thanks.
MelbaDT
Gotcha — keep us posted after you've installed it. We wanted to ensure it will work as it should.
Melba
aatienza
Hey Jconnell65,
Chiming in to check if you still need help with this?
Feel free to respond to this thread if you have additional questions or concerns and I'd be glad to answer it for you.
Archie
Jconnell65
Still haven't put back up yet. Hopefully this week. Thanks
aatienza
Hey Jconnell65,
Understood — let us know how it goes.
Archie
aatienza
Hey Jconnell65,
How's it going? Still need our help? Feel free to let us know if you do.
Archie
MelbaDT
Hey here,
We haven't heard from you in a while so we'll be locking this thread if there is no update within the day. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community.
Melba
