02-14-2023 06:00 AM
I have a dehumidifier installed with my nest thermostat. Everything works, but the dehumidifier continues to run past my set point. For example, the humidity is currently set at 50% and the actual humidity measured by the Nest is 47%, but nest is still telling the dehumidifier to run.
This is causing extra heat in my house, which makes the AC run more. Any advice on how to fix this issue so that the dehumidifier only runs when it needs to? Or is the dehumidifier supposed to run a little past the set point in order to avoid cycling?
03-12-2023 11:19 AM
Hi drewcolvin,
Thanks for reaching out — I'm sorry for the delay. I just want to follow up if you're still encountering the issue. Please let me know as I'll be willing to assist you.
03-15-2023 11:38 AM
Checking in if you still need help. Please let me know, as I'll be willing to assist you further.
03-16-2023 11:44 AM
Hello drewcolvin,
I'm just checking in to make sure that you've seen our response. Please let us know if you have any other questions or concerns, as I'll be locking this thread in 24 hours.
03-17-2023 07:12 AM
Hi Jenelyn,
Yes, I still have the issue of the dehumidifier running past the set point. Sorry for the late reply!
04-13-2023 03:51 PM
Hey drewcolvin,
Thanks for the update. I know it's been a while. I'm sorry for that. A few questions: what type of Nest Thermostat do you have? You can visit this link to check what type of thermostat you have. Has your dehumidifier worked before, or is it the first time you're using it? Also, try to reseat your dehumidifier wire on your thermostat but make sure to turn the breaker off first before touching any wires.
I appreciate your help, @David_K.
04-17-2023 10:03 AM
04-18-2023 11:47 AM
Hello there,
