Dial won’t work in nest thermostat
Kpeter04
The dial will no longer turn in my nest e learning , I can only click it but can’t adjust the temperature or find the code to add it to my wifi. Is this fixable or do I need to buy a new , non google thermostat ?
thanks
6 REPLIES 6
Anonymous
Not applicable
If you can't turn the ring, then you'll have to replace the display. Check the warranty of the device to see if Google can replace it.
MrVacca
Silver Product Expert
@Kpeter04 - A factory reset might do the trick!
First of all, why did the nest loose it’s WiFi setup? Are you saying the ring rotates but he screen does not respond?
Ken, The AC Cooling Wizard
If my answer solved your problem, click Recommend this Answer below, and If it helped you, please give a Kudo.
Hi all,
I wanted to stop by and see how I could help, and thanks to everyone for the assistance.
@Kpeter04, I wanted to make sure that you'd seen their response. Could you please try this step? Tap and hold the thermostat screen for 10 seconds until it shuts down to restart.
Please let us know how it goes.
Jeff
Hi Kpeter04,
I just wanted to check in real fast to see if you saw the replies here and to find out if you still needed any help on this. If you're still needing assistance, please just let me know and I'll be happy to continue helping.
Jeff
Jeff
Jeff
