Do I need 2 heat link devices if I have 2 Thermostats
ItsonlyBing
Current set up:
Nest Thermostat model Display-3.4 with Heat Link Amber-2.5
I would like to add a Nest Thermostat E to a different room.  This comes with a Heat Link.  I already have the above Heat Link installed, do I need to install the one that comes with the Nest Thermostat E.
If the Thermostat E isn't compatible, can you confirm what is please - I'm looking a the 'E' as it has a built in stand.
Thanks in advance.
2 REPLIES 2
Frustratedddd
Yes you do, as the E is a different beast.
ItsonlyBing
ok - thank you.
I don't want to have 2 heat links - not even sure if I know how to add them either.
Is there a better way to control the heat in the 2nd room, within the nest options?
