Dual Fuel and compressor wiring
CBlack
There appears to be a mistake in wiring diagrams.
My units (Tempstar) the Y1 is compressor (defaults heat).  The O/B is the reversing value or change over, that switches it to cool.  All descriptions contradict this.  Anyone have this as well?
2 REPLIES 2
aperezdeleon
Hi there CBlack,
Thanks for reaching out to our community!
There could be some confusion with some specific system's wiring. In this case, Y1 is for a compressor, which activates in heating and cooling modes.
Some HVAC systems might have different wiring configurations. In conventional systems, Y1 is typically used for cooling, while in multi-stage systems, it might control only the first stage of it.
This can lead to descriptions focusing solely on the cooling function.
If you want more information, I would recommend you refer to your heat pump's manual for the official wiring diagram, so you can verify what function your Y1 wire triggers.
Angel.
Y (Y1 for these Google things) is triggered both by heat & by cool selection i.e. it is the compressor 'on' circuit.  O/B is the reversing valve or changeover valve if that minimizes your confusion.
Even in setup test procedures the stat never notes it has activated O/B, only Y1 and G which is the same in the heat or cool cycles test, again proving Y is compressor.  It does not show O/B is active, but testing board it is.
