Dual fuel temperature switch hysteresis
jfields026
I have a Nest 3 and dual fuel heat pump that switches to gas when the temp outside hits 35 F.  Sometimes the outside temp hits 35.1, then 34.9, the 35.1 and so on. Maybe it’s not that close but it hovers around the boundary. When that happens I can hear my heat turn on, switch fuels, and sometimes switch back. Is there a way to create or edit the dual fuel temperature hysteresis value so it just stays on whatever fuel it started with for that cycle, or some configurable amount of time?
Ryan_G
Hope this helps!
Kind regards,
Ryan
