08-11-2023 06:51 AM
The Eco mode on both of my thermostats seems out of control. I don't have any away routines enabled and I can't find a setting in the Google Home App that allows for it to be removed. This is all happening while I am in the house and even in the same room as the thermostat.
08-28-2023 10:01 AM
@DrConcrete, thanks for doing that. Please continue monitoring your Nest Thermostat and system's behavior. Let us know if anything comes up, as we'll be willing to assist you.
I appreciate the help, @HVAC and Zoe.
08-11-2023 09:18 AM
You need to turn off other features like learning, auto schedule, cool to dry & airwave. Also might need to delete your schedules. That’s if you want to always operate the nest manually good luck
08-11-2023 10:21 AM
Thanks. The Home App doesn't appear to have any settings around learning.
08-11-2023 10:34 AM
My bad That might might be the term they use for auto schedule or airwave good luck
08-14-2023 07:28 AM
Just going to throw my thermostats and start over. There has to be a brand out there with better support.
08-25-2023 02:28 PM
@DrConcrete, thanks for reaching out to us, and I'm sorry to hear about the situation. I want to check if you are still in need of any help. If so, to disable your Nest Thermostat 2020 automatically swiching to Eco mode, please follow these steps:
Let us know how it goes.
I appreciate your input, @HVAC.
08-28-2023 08:27 AM
Hi Zoe.
All routines have already been disabled.
08-28-2023 10:01 AM
08-28-2023 10:07 AM
@Jenelyn_O The issue is still not resolved. These steps were included in my original post. The issue is I don't have any settings enabled and the thermostats continue to switch to eco mode.
09-05-2023 09:46 AM
Hey DrConcrete,
Thanks for keeping me in the loop. I'm sorry for the delay. Please perform a factory reset on your Nest Thermostat. First, remove your thermostat to the Google Home app. On your thermostat, go to the Settings then go all the way down to select Factory Reset. After that, continue with the setup in the Google Home app.
Let me know how it goes.
Kind regards,
