06-27-2022 03:11 PM
I've seen online where there's the ability to control the fan speed (Auto, High, Medium, Low). However when I go to settings I can't find anything that allows me to control it. I just see Fan Schedule, but there's nothing there that allows me to control the speed of the fan. I have Y1, Y2, G, C, Rh, and W connected if that makes a difference.
Also, is there a way to have just the fan always running? I like it to circulate the air constantly. It "seems" like if I set the schedule to always in settings that does it, but wanted to confirm if that's the way to do it or not.
07-02-2022 01:08 PM
Hi Feedback,
Thanks for reaching out. This would depend on the type of Nest Thermostat that you have and if you have a multi-speed fan installed. You're correct about the fan schedule, you can set it to "Always" to keep it running.
You can also click on this link to learn more about this.
Edward
07-05-2022 01:41 PM
Hi Feedback,
Edward
07-06-2022 01:46 PM
Hi Feedback,
Just checking in to make sure that you've seen our response. Please let us know if you have any other questions or concerns as I will be locking this in 24 hours.
Edward
