Fan will not shut off while using the nest thermostat
TonyStracuzza
Hi there. Ever since I connected my new Nest thermostat, the fan has not stopped running. It’s been well over 2 hours. Anyone know a solution that works for certain?
I’m not getting the other issues that people seem to have with the C wire missing so I doubt it’s that. Any other ideas?
I did the nest power connector and it worked thanks
7 REPLIES 7
How is it wired?
Not having a C wire can cause the fan to operate when not expected
I don’t have a C wire but I am not getting the typical errors that other people who had the C wire issue were getting (ex. Low battery). Should I try moving the G wire to the C wire for now?
I never recommend using the G wire as a C wire.
Is there a spare wire by chance? If there is you can use it to create a C wire, or you can get the Nest Power Connecter which will create one for you.
Jeran
Hiya TonyStracuzza,
Thank you for coming back with your solution! In that case, did you have any other questions or concerns we can address?
Thanks for helping out on this thread, Patrick_Caezza!
Jeran
Nope that’s all, thank you
You're welcome. SInce all of the questions here has been answered, I'll go ahead and close this thread in 24 hours. Feel free to start a new one if you need assistance with your Nest Thermostats and the community would gladly help.
Princess
