02-06-2022 05:21 AM
My fan is constantly running even though it says it’s off. Is there anyway to get it off?
02-06-2022 02:44 PM
My fan was not turning off either. I came here and found a few things...
1. New update messed things up and Google hasn't fixed it yet
2. I turned off the breaker and furnace (which shuts down fan) I moved my red wire from Rc wire to RH
3. Turned back on breaker and system
4. Hold down Nest for 10 seconds to reset
5. Turn off max/min settings
I'm not sure which thing did the trick but nothing can hurt and my system is ok until they fix the software issue.
07-05-2022 11:49 AM
Hope this helps!
Kind regards,
Ryan
