09-20-2022 06:57 AM
I just built my home and the new HVAC systems do not have a separate controller for fresh air ventilation they rely upon the thermostat control. I replaced my thermostat with a nest not realizing apparently there is no way to control the fresh air ventilation with nest thermostats. Is that correct?
09-27-2022 09:23 AM
Hi tsilkwood,
Thanks for reaching out. I'd love to know more about this. Could you share the make and model of your previous thermostat and how it's wired?
Edward
09-30-2022 09:25 AM
Hi tsilkwood,
Edward
09-30-2022 09:36 AM
Hi Edward,
Sorry for the delayed response. The Honeywell thermostat model I had was TH6320ZW2003. However, it was not WiFi enabled so I installed a Nest Learning Thermostat Model A0013 Item: T3016US. The whole house ventilation system is connected to the HVAC but controlled by the thermostat. There is no options that I can find on the Nest Thermostat to control the ventilation settings.
As far as how it is wired, I'm not sure what you mean. You can only wire it one way for it to work, matching wires with connections per instructions. The Nest Thermostat works, it just doesn't have the additional settings to control the ventilation system. The inspector said he thought Nest had addressed/fixed this problem with the later model thermostats?
10-04-2022 10:14 AM
Hi tsilkwood,
Thanks for the response and I'm sorry for the confusion. We don't have any news to share about the feature to control the fresh air ventilation. We appreciate users who are keen on sharing their thoughts with us. We're always looking to improve — we'll take this as feedback.
Edward
10-07-2022 10:15 AM
Hey tsilkwood,
Edward
10-11-2022 08:54 AM
Hi tsilkwood,
Edward
10-11-2022 11:28 AM
Well considering you basically said "can't help ya", I guess you can close the subject. I was told Google was updating (or had in the latest version) updated the nest thermostat that would allow you to control your whole home ventilation system (that is attached to the HVAC by the way). So either that is not true, or you need to hit response quota and have no idea what I'm talking about!
10-12-2022 09:06 AM
Hi tsilkwood,
We hear you. Our team is working hard to deliver the best experience for our users — we'll take this as feedback. Keep your eye on the Google Nest Community page for any updates. Please let me know if you have other questions or concerns as I will be locking this in 24 hours if I won't hear back from you again. Feel free to start a new thread and we'll be happy to help.
Check out this link on how to file feedback.
Edward
