09-27-2022 11:38 AM
I wired in the thermostat, shows nothing, changed batteries, still nothing. Any way to check if thermostat works.
old thermostat works just fine.
10-01-2022 01:58 PM
Hi Rhaendler,
Thanks for reaching out. I'm sorry to hear that you're having an issue with your Nest Thermostat. I'd love to know more about this and I have a few questions:
Also, if you haven't yet, please try the steps on this link to isolate the issue.
Edward
10-03-2022 09:50 AM
Not sure which it is, I gave the serial number to the tech support specialist. Case # 1287000033008 and case # 1-717000032718. I sent photos of the wiring and my system. All appeared correct. I placed new batteries in the unit, energizer 1.5 . Nothing powered up.
I am in Cedar Rapids, Iowa
10-04-2022 06:28 AM
SN 22181J3DB21WFK
10-05-2022 11:30 AM
Hi Rhaendler,
Thanks for the response. For some reason, I can't pull up the case number that you provided. If possible, could you share a photo of your Nest Thermostat? Also, when did you purchase it?
Edward
10-11-2022 08:47 AM
Hi Rhaendler,
Edward
10-12-2022 08:54 AM
Hi Rhaendler,
Edward
