07-11-2024 03:51 PM - edited 07-11-2024 03:53 PM
Gen 3 E74 code no power to Rh
first I saw low battery message and then thermostat went out
i I recharged the battery and plugged it back to the base now seeing E74 code no power to RH
i reset the thermostat to start fresh and rebooted several times no luck so far
the device is 5 years old and never had any issue so far
07-15-2024 04:08 PM
Hi Pranav,
Thanks for reaching out. I understand your Nest Learning Thermostat 3rd Gen is displaying the E74 code, which indicates no power to the RH wire. I know it's frustrating when your thermostat isn't working properly.
To help you solve this situation, I've included a link to guide you on "Troubleshooting thermostat power issues during hot weather (E3, E4, E23, E24, E73, E74, or E195 help...). This guide provides step-by-step instructions to identify the potential cause of the problem.
Please let me know if you have any other questions.
Manuel
07-16-2024 05:39 AM
Thanks Manuel, got it fixed. It was a faulty wiring on the condenser pump which did not allow power from HVAC to the thermostat.
