10-05-2023 01:39 PM
Hi I have a Gree heatpump with a KX 75 panel
The Kx75 wired panel has 2 connections - H1 and H2.
The wires running to the connections are twisted pair - orange/white and blue/white
As its a heat pump its heat, cool ,dehumidify etc.
What is the right wire locations on the Nest 3 plate .
10-08-2023 09:41 PM
Hello AndrewC2,
Thanks for posting here in the Community. Just to check, do you have a photo of the wiring configuration on your current thermostat? Can you please send us a photo of the control board or the KX 75 panel?
Below are the steps on how to upload a photo or video:
Hit reply or Start a new post.
2. Click Insert Image.
3. Choose an image source location.
4. Follow the on-screen instructions.
Also, you can tap the "Drag and Drop" option. Maximum attachment is 5 MB.
Edmond
