12-03-2023 11:27 AM
We've had our nest now for a few months and got it working well.
Yesterday I had to restart the WiFi in our house and I don't think the Nest ever reconnected (not sure if that matters but providing context)
Today at 1 PM I noticed the nest shut down. When I tried to restart it, I got a blinking green light and the message "please attach the display to the base". I had not of course removed the unit from the wall so it seemed like an odd message.
I removed and reattached it - same message. Tried to charge the battery using a USB connection many times. Each time, I reconnect display to base, the start-up starts, stops after the colors start swirling and I get the same error message.
Getting cold in the house - help would be appreciated.
My nest does NOT have the C wire used in its wiring if that matters
12-07-2023 08:45 AM
Hi JGFayan,
Thanks for reaching out and for being a step ahead of us. If your Nest Thermostat’s display LED flashes a green light, it means the thermostat is on the software update phase software, boot up phase, restart phase, or the thermostat is connected to a charger. Usually, when the thermostat flashes a green light, it only lasts a minute or two. Once the thermostat finishes the software update and restart phase , the display turns on.
If the thermostat continues to flash a green light and remains unresponsive for more than 5 minutes, try the troubleshooting steps here:
Let me know how it goes.
