01-24-2024 03:56 AM
I see lots of posts going back years about the inability to set a lock range in heat/cool mode, which is an essential feature for rental home use. It would seem like a simple feature to add, but for some reason it has never been implemented. Can someone from Google/Nest advise when this essential feature will be implemented please….
01-30-2024 01:47 PM
Hi U722580,
Thanks for posting here in the Google Nest Community. We'd be happy to take a look into this for you. If you’re using our Nest Learning Thermostat, you can set heat/cool mode and lock the Nest Thermostat so that no one can change the target range temperature. You can follow the steps below:
Nest Learning Thermostat:
After setting the Heat/cool mode. Follow these steps to lock your Nest thermostat:
Let us know if that helps.
Renz
01-30-2024 03:01 PM
Hi Renz,
Thanks for your reply, but unfortunately it doesn’t help!
The issue (as I previously said and as you’ve confirmed) is that it is NOT possible to set a temperature lock range when in heat/cool mode. There NEEDS to be a facility to set 2 lock ranges when in heat/cool mode. One for heat and one for cool. This is a KEY requirement when the Nest thermostats are installed in a rental (particularly a short term rental) home. Otherwise when the thermostat is locked in heat/cool mode there is NO possibility for the renter to adjust the temperature.
it would seem a simple, yet highly necessary enhancement to make.
When can it be added?
01-31-2024 02:01 PM
Hello U722580,
Thanks for getting back to us. We appreciate people who want to share their thoughts with us. Our team is working hard to deliver the best experience for our users, and we're always looking for ways to improve. You can Share feedback about Google Nest in detail.
Renz
