05-08-2022 09:10 AM
I followed the installation instructions to the letter. I was provided a wiring diagram from the Nest app setup and wired the system accordingly. When I switch to the heating function the heat does not switch on and fan will cycle continuously. Attached are the pictures of my wiring configuration. Please help!
05-08-2022 08:49 PM
Is that brown wire a jumper between the W1 and X2 terminals on the original thermostat?
05-09-2022 06:30 AM
Yes, there is a jumper between W1 and X2 as well as RC and R. When I perform the tests, fans turn on during the heating phase but only cold air comes out of the registers. Any help is greatly appreciated! Thank you.
05-21-2022 03:39 PM
Hi JA7,
Thanks for reaching out here in the community.
Let's check a couple of details for us to further assist you. It seems that you already connected the wire to the Nest thermostat correctly. The X1 wire is no longer needed. Since it looks like a heat pump, we could check the OB orientation and test if your heating works.
Thank you for your assistance, Patrick_Caezza.
Let us know how it goes.
Ryan
05-23-2022 07:45 AM - edited 05-23-2022 07:46 AM
Hello Ryan,
Thanks for the suggestion. I'll have to reinstall and check the OB orientation. Any other suggestions while I'm checking? If this doesn't work, I'll have to reinstall the original thermostat because I need a working system.
Thank you,
JA7
07-18-2022 03:25 AM
Hey JA7,
Thanks for the reply.
I'd like to check on how your Nest Thermostat is doing after changing the OB orientation.
Ryan
07-21-2022 12:08 PM
Hey JA7,
I wanted to check in and see if you managed to see Ryan's post. Please let me know if you have any questions from here. I would be happy to assist, and ensure you are good to go.
07-22-2022 10:32 AM
Hey JA7,
I want to ensure you are good to go, and everything is working properly. Please let me know if you are still having trouble, as I will be locking the thread in 24 hours due to inactivity.
07-27-2022 03:07 PM
Hey JA7,
I am sorry to hear your system is not compatible with the Nest Thermostat. I know the situation was not an ideal one. I am going to lock the thread at this time, and if you have any questions from here, feel free to create a new post.
07-22-2022 01:19 PM
Orientation did not work. As a matter of fact, I had a Nest installer come in to "reinstall" the thermostat. The thermostat turned on the heat when it was set to cooling and cooled when set to heat. He then said the thermostat was not compatible with my system and I ended up replacing it with a plain old "dumb" thermostat. Highly disappointed with the whole situation.
regards,
JA7
