Heat link has no power
Joann3
Hi …
everything has been working fine, i went on holiday and returned to low battery on my nest. I have used a few troubleshoots and  have tired to reset by pushing the reset button for 20 seconds but there is no light (green/yellow)
I have checked all wires and connections and all is fine. The heat link is just dead.
luciaaa
Hi, @Joann3!
Thank you for reaching out to the community. I'm sorry to hear that your Heat Link seems to have no power after your return from your holidays. I appreciate you taking the time to reset your Heat Link and perform other troubleshooting steps. I'm here to help!
To provide you with the best assistance, please answer the following questions:
  • What is the model of your thermostat? Here’s a helpful article about how to identify your thermostat model.
  • Could you describe the troubleshooting steps you've taken besides resetting the Heat Link?
  • When was your thermostat installed?
  • When did this issue begin?
  • Have you experienced any recent power outages?
  • Have you recently had service or maintenance on your electrical, plumbing, or heating system?
  • Besides the low battery message, are you seeing any error codes displayed on the thermostat or within the app?
This information will help to determine the best next troubleshooting steps.
Please keep me updated.
Best regards.
Ana
