07-23-2022 11:39 PM - edited 07-24-2022 01:27 AM
I have an issue with the heat link, it stopped working a week ago. I tried the 30 second button press reset, I tried turning the power off but nothing happened.
What can I do?
07-28-2022 12:05 AM
Hey there, thanks for reaching out. I'm here to help. Could you tell me when it started happening? Which type of Nest Thermostat do you have (Nest Learning Thermostat 2nd gen/3rd gen, Nest Thermostat E, or Nest Thermostat 2020)? Also, what country are you located in?
07-28-2022 01:58 AM
It's a Nest Learning Thermostat 3rd Gen.
I've observed two weeks ago that the led from the heat link is off. I tried everything, I've moved the thermostat closer to heat link, I've changed the plug and so on.
I'm from Romania.
Thank you
07-28-2022 02:34 AM
@CatalinT You did a great job in troubleshooting. Have you tried turning on Manual Mode to verify boiler activation by pressing its button once? Does anything happen?
07-28-2022 03:23 AM
Yes, I tried, nothing happened 😞
07-28-2022 04:45 AM
@CatalinT I am sorry that you're having issues with your Heat Link, but we'll find a solution together. Did you also check that the breaker switches are set to on or the fuse board hasn't tripped?
07-28-2022 06:59 AM
Everything was functional...
Is there a fuse board on the heat link?
07-28-2022 07:08 AM
I understand. When I mentioned the fuse box, I was referring to the main panel where all the circuits are.
07-28-2022 07:28 AM
Nope, the fuse box is ok.
07-28-2022 07:32 AM
In some cases the boiler will have an additional isolation switch which can turn off the power to both the Heat Link and the boiler. Can you try switching that off/on again to see if anything changes? If you don't have an isolation switch for the boiler, turn the fuse board switches (circuit breakers) off and on.
07-28-2022 08:01 AM
Same situation. After switching the fuse off and on, the heat link is in the same state and the heating system is on.
07-29-2022 12:07 AM
Thanks a lot for trying, @CatalinT. I'll forward an email containing instructions regarding the steps you need to follow in order to have your case registered in our system. Please check your email and reply there, but let me know once it is done. We'll continue afterwards.
07-30-2022 11:43 PM
I've summited the requested info.
Thank you
08-01-2022 05:40 AM
08-03-2022 06:03 AM
Since I haven't heard from you in a while, I'll have to close this thread. Should anything else come up, please open another thread and we'll take it from there. Have a good one and stay safe!
