01-13-2022 11:46 AM
My heat link suddenly has no power. It’s wired in to the boiler switch. I had it serviced on Tuesday. Been fine yesterday and today then suddenly died. No power after 30 seconds. No green lights on. No blown fuses to fuse box. Switch to boiler controlling boiler normally. Help!
01-13-2022 11:59 AM
Same here for me as well. Contacted support via chat and they are sending me a replacement free of charge.
01-17-2022 02:58 AM
Hello @Chrissy73,
Thanks for reaching out. I'll do my best to get this sorted for you as soon as possible.
Here are some helpful troubleshooting steps:
Press the button on the Heat Link and check if you have any lights on it
Check if the circuit breakers and the switches are set to on
Turn them off and then back on
Press on the button again and check for LEDs
Could you also help me with some answers to these questions?
How many zones ( thermostats ) are present in the setup?
01-20-2022 04:03 AM
Hi there. Just checking in. How's it going with your Heat Link?
01-21-2022 04:26 AM
